I’ve got a pflow disk cache with 800,000 particles and I’m using the Shape Instance modifier as a post-cache operator. It works great in the viewport but vray can’t seem to render it. I get this error:
[2015/Sep/4|13:34:04] Extracting frame data from FrameParams.
[2015/Sep/4|13:34:04] Extracting frame data from VRender Environment params.
[2015/Sep/4|13:34:04] Extracting frame data for fields.
[2015/Sep/4|13:34:04] Extracting frame data from node (PhysCamera001).
[2015/Sep/4|13:34:04] Rendering from camera PhysCamera001
[2015/Sep/4|13:34:04] Setting up frame region.
[2015/Sep/4|13:34:04] Clearing previous contents of frame buffer.
[2015/Sep/4|13:34:04] Calling beginFrame().
[2015/Sep/4|13:34:04] Entering beginFrame().
[2015/Sep/4|13:34:04] Setting RenderGlobalContext.
[2015/Sep/4|13:34:04] Broadcasting NOTIFY_RENDER_PREEVAL.
[2015/Sep/4|13:34:04] Updating the tone operator.
[2015/Sep/4|13:34:04] Preparing camera sampler.
[2015/Sep/4|13:34:04] Calling update().
[2015/Sep/4|13:34:04] warning: Bitmap pager is enabled; rendering might be slower
[2015/Sep/4|13:34:04] Updating scene materials for time=0
[2015/Sep/4|13:34:04] Loading bitmaps for ""
[2015/Sep/4|13:34:04] Updating ""
[2015/Sep/4|13:34:04] Loading bitmaps for "Snow2"
[2015/Sep/4|13:34:04] Updating "Snow2"
[2015/Sep/4|13:34:04] Loading bitmaps for "Map #109"
[2015/Sep/4|13:34:04] Updating "Map #109"
[2015/Sep/4|13:34:04] Loading bitmaps for "Map #121"
[2015/Sep/4|13:34:04] Updating "Map #121"
[2015/Sep/4|13:34:04] Loading bitmaps for "Matte"
[2015/Sep/4|13:34:04] Updating "Matte"
[2015/Sep/4|13:34:04] Preparing objects
[2015/Sep/4|13:34:04] Updating object PFS_FineSnow001->PFS_FineSnow001
[2015/Sep/4|13:34:04] Number of particles for "PFS_FineSnow001->PFS_FineSnow001" is 0
[2015/Sep/4|13:34:04] Updating object PFS_FineSnow001->Event 005
[2015/Sep/4|13:34:04] Number of particles for "PFS_FineSnow001->Event 005" is 800000
[2015/Sep/4|13:34:16] error: UNHANDLED EXCEPTION: Preparing objects
Last marker is at ./src/vrayrenderer.cpp, line 3259: Preparing camera sampler
Seems to happen regardless of what “Geometry” render typ I use (Single mesh, Multiple meshes, mesh per particle).
