Crash using normal shader inside material which is used as Material Override
It’s simple to reproduce the bug, just turn on Bump channel in material which is used as Material Override, and click on Render or IR Render in Corona VFB.
There is the Normal shader with texture in Bump channel, and it crushes Cinema.
Mac OS X El Capitan 10.11.6
Cinema 4D R20.026
Corona Renderer 3 (Hotfix 1)
scene.zip (8.36 MB)
Hi, Thanks for the report. I was successfully able to reproduce this and will report it immediately. Thanks again :wink:
Yay, thank you and Corona team! You’re the best!
