Crash when rendering image sequences used as batch camera renders
Status: new
I would like to report a recurring stability issue I am experiencing when rendering image sequences in Chaos Vantage.
In my workflow, I often use an image sequence not as a traditional animation, but as a fast way to batch-render multiple static camera positions (each frame corresponds to a different camera position, with no continuous animation). This is a very common and efficient workflow in production.
However, when rendering such sequences in Vantage, the application consistently crashes after completing the first frame (usually during the transition to frame 2). This happens even when:
  • The camera movement is minimal or discrete
  • No animated materials are used
  • The goal is only to output independent still frames
Through testing, I noticed that rendering each frame individually as a still image is stable, while rendering the same views as an image sequence causes frequent crashes. This suggests a memory or buffer reinitialization issue between frames.
It would be extremely helpful if Chaos Vantage could:
  • Improve stability when rendering image sequences intended as batch still renders
  • Or provide an explicit “Batch Still Render” / “Multi-view render” mode that does not reinitialize animation-related systems between frames
This would greatly enhance Vantage’s usability for production workflows where speed and reliability are critical.
Thank you very much for your work on Chaos Vantage and for considering this feedback.
Submitted on AHA Ideas (VANTAGE-I-295).
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
