I just encountered some strange crashing behavior when trying to Store the VFB after resetting the render settings in the attached file.
In it’s current state, the file works just fine, you can Store the VFB without issue. But if you reset the render settings and try to Store the VFB after doing an IR it hangs and crashes max.
I’ve tried resetting render settings, clearing out the elements, turning the caustics and adaptive light solver on/off, and the crash still happens every time with reset settings.
What’s bizarre is that if I open Max without any start file, so it’s totally default and switch my render to Corona, the same crashing behavior occurs…
Thank you for the information. I am not able to reproduce the crash here. Would you be able to create a minidump? Instructions on how to do this are in my signiture.
Could you provide me with some more information, which version of Max and Windows are you using? Could you also confirm the rest of the specification of your computer?
A little more testing revealed that I can Store the VFB while rendering and after the max pass limit has been reached without any crashes. It’s only if I stop mid IR and try to Store.
Still crashes unfortunately. There was a bit of confusion in the office here about the steps I was taking to cause the crash, so I just want to clarify.
If you open the max file I first attached here, go to the performance tab and tick Fast Preview Denoise During Render, so it’s on. Then start an interactive render in the Corona VFB, then click stop and try to Store from VFB, it crashes all 4 computers now (including the Threadripper, I’ll edit that earlier post).
I have managed to narrow the crash down to one setting. If you switch from “Use photographic exposure” to “Use simple exposure” the crash will no longer happen. Also disabling the “Fast preview denoiser” stops the crash from occuring.
I hope for the time being this is a suitable workaround.
