Crash with complex projets
I am under vectroworks 2023 sp2, Windows 10 RAM 128Gb and Nvidia Quattro RTX5000 8GB VRAM.
When I run Enscape with a fairly complex project that contains a lot of plants for example, Enscape often crashes at startup.
To avoid this, I have to launch Enscape with only one layer displayed and activate the other layers one after the other, slowly.
I think my configuration is powerful, I wonder why Enscape does not accept the project with all layers displayed at startup.
For information, when the project is fully loaded, my RAM is at 30%, the graphics processor at 5% so at very low values.
All of my drivers are up to date :wink:
Nicolas
Whenever you experience crashes like these, feel free to also submit a dedicated feedback report as detailed here. This way our technical support team will get back to you with a solution / explanation as to why you experience this behavior exactly.
Thanks a lot in advance.
@Nico_be
Thank you for sharing with other users the issue you ran into. Once you learn what caused it and hopefully a solution or workaround, please share that with us!
Yes I will share the solution if it is fixed because it seems to be a known bug.
I sent feedback and this is the response I received.
