as mentioned in the topic name, grass assets that have edge trimming active in the Opacity slot are crashing the render right at the start. This is new in 2024.1 and / or Corona 10 (HF2). Unfortunately I can’t test it with C4D 2023.2.2 and Corona 10 (HF2), only without the hotfix. About ~ 1 year ago today I’d kind of the same problem with crashes while Edge Trimming is active and I’m not really sure what solved the problem. Did some trail and error to get rid of that crash but I guess it solved itself over time. But now the problem happens with a newer version, still working with 2023.
Preparing a test scene is always a great way of troubleshooting.
Got to the point where I would say, the grass assets created with Forester will crash while using Edge Trimming. Once converted, it renders without any problem. Looks like that thread was opened a little bit too fast and I’m off to the other support site now.
Thanks for the files, I will add them to our internal bug report. Can you also try this with a Corona material instead of using a standard C4D material and also another grass asset from our Cosmos browser?
Back again. Replaced the material with a Corona Physical Material and the Edge Trimming in the Opacity slot. Still a crash after I start rendering. Bug Report attached. _BugReport.zip (156 KB)
Okay, thanks for testing and letting me know. I will log the report. Also, does it crash if using a grass assets from the Cosmos browser?
(Internal ID=1240086686)
A quick update to that problem from ‘the other side’, the Forester Support. Not quite sure if I could update the Support ID / Internal ID in a different way than this.
We could reproduce the bug. However, it’s not a Forester or MultiFlora bug.
The bug needs to be resolved on the Chaos side.
It’s best to email them with a simple scene (plane + Forester MultiFlora simple grass + chaos scatter) and have them take a look at it.
The bug is only visible in 2024 as far as we can tell. So that makes it easier to track down.
Hi! Sorry for coming up with an older topic, but I’ve switched to C4D 2024.2 and Corona 11 for a new project and after adding my grass cloner I’ve noticed that the Edge Trimming isn’t working. It doesn’t crash, yes. But the edges aren’t clean as it used to be. Again, converting the Forester Asset to a polygon solves the problem. When I saw the fix in the latest release notes I only checked if the rendering crashes but never if the Edge Trimming is doing its job. I’ve quoted my post because there I have my test scene which still is valid for the actual problem.
Hi! Just wondering if there are any news regarding this issue? Or should I contact support via the support homepage?
We now already tried to re-install C4D + Corona 11 on a PC, but somehow the Trimming doesn’t apply anymore.
No problem. Was just wondering if reaching out via the forum is the right way anyway. I really like it that way, at least :).
I’ve four screenshots attached. First two are with 2024, last two are with 2023. Same scene, nothing changed.
What I’ve noticed: 2024 doesn’t use Edge Trimming properly and even the ‘Full’ mesh display doesn’t work either. In the 2023 scene the wireframe shows some assets - but nothing in 2024.
