Crash with IR after Ctrl+duplicate in object manager
Hi Houska, thanks for that.
There is another one… IR running and copping object by dragging and holding ctrl key… it quits.
Files sent to you.
Thanks.
I just tried that scene, ctrl+drag to clone the box object while IR was running, and got no crash… But there are some plugins missing - VRay, VRay PowerShaders and Py-Extrude Generator. Maybe those plugins are causing the crash?
Thanks for testing, please see this… if I am doing anything wrong… update me
sending you revise file II (copy pasted in new file)… I hope you will not see any missing plugin in that.
Thanks.
ahhhh… got it.
Py-Extrude Generator (Py-ParametricTools)… from maxon lab is causing crash Corona.
May be other user also using this plugin… please see if you can tweak this and not crashing. Thanks.
It does not crash for me, whatever I do. I will ask you to check it in the newest daily build, once it’s out.
