Crash with OSL wParallax
I can also confirm, the error occurs in max 2023 and corona9 (also vray6).
Not sure if it is max problem, renderer problem, or osl (however, osl seems to work fine in previous versions).
I was doing different tests with different material setups, original wparallax material setups use multimaps, I have tried without and it crashes but less ofthen.
A very strange thing is that wparallax original scene works perfectly fine with alot of constand tweaking and basically pushing everything to the limit, absolutely no crashes occur. Only when importing the planes into a new project scene, then the crashes might occur, sometimes it works just fine, and other times just randomly crashes. So, maybe the issue is with Material Edtior, because in a new scene, the materials are not yet loaded?
UPDATE: Just tested same scene in Max 2022 + Corona 9, there is no crash, works totally fine with all the tweaking of osl maps in material editor.
Hey there,
are there any updates on the issue since February?
I experience the same problems the members before me described: Constant crashes since I have some wParallax planes in my scene. It doesn’t necessarily happen after the first Interactive Render - the crashes are pretty random, but quite constant in their appearance.
I use Max 2023 with Corona 9, both updated to the latest product versions.
Same for me, even the new version of parallax shaders crashes randomly but inexorably. it is totally unusable in production because it is far too unstable. I tested them on max 2022, 2023 and 2024 with corona 9 without success..
@mienda
Well, I wouldn’t go as far as calling it “totally unusable”, as I managed to finish a competition, using parallax for the retail areas and thus saving tons of time and render ressources, but it surely is infuriating and far from how it should be.
The workaround I went with was setting up the parralax while the scene was still lightweight. Had to put up with constant saving and occasional crashes for a while, but after the parallax planes were set up, I just made the layer they were on invisible and was able to continue working without further crashes. Then, I’d just turn them on for preview renders and the final production (4K) and had no problems finishing the project.
Hope the issue will get resolved soon, though. Parallax solutions are a big help and it would be great to be able to use reliably.
Any updates on this? Happens mostly with a lot of Parallax maps in the scene.
Same for me, I hope it will be fixed soon because I suffered random crashes when opening, manipulating and rendering with all OSL parallax systems (as well with the new version of Wparallax and versions of Evermotion ( archmodels 267 and 271) I tested these materials on 2 different systems (threadripper 3990X and Intel i9 13900HX) with 3dsmax2024 and corona 9 HF3 without success.. These materials are not reliable at all and are unusable in production.
I have the same problem, on Corona 10.1 and max 23 and 24 too. I schould render an animation with the maps, but currently this is not possible, since max crashes after the first render almost on each rendernodes…
Anyone found a workaround?
Thanks.
has this been solved, or am I missing something? Since the topic has been moved to the solved section…
Thanks.
Weird, why is this in solved? The OSL wParallax has such a potential to revolutionize workflow in ArchViz but not if it’s crash-fest :- (.
It could be the fault of the particular OSL, but not OSL in general by itself since I still use lot of OSL nodes in my shaders that are completely fine.
Yep, constant crashes here for me too.
Yep, this is definately not solved yet.
We would love to use it in production, but simply cannot due to instability.
Guys, you should try the shadersbox method, also from wParallax. It uses an already unwrapped box, you just have to apply the exr map to it. For me, it’s working fine with the same maps as the osl version, but without crasing max. There are no osl maps in the scene, but the windows have the same 3d effect.
The box method is just not as convenient as using simple plane behind the window. It’s much harder to set up procedurally if there are many building types involved.
Planes + OSL are so much better and faster to use, if only they weren’t crashing.
Sorry for the lack of updates. According to the minidump that we received, the crash is inside 3ds Max and it can be reproduced without having Corona installed at all.
If you are not happy about something and you have a scene and/or minidump, please always contact us about it here: https://support.chaos.com/hc/en-us/requests/new
The best thing we can do here is to contact Autodesk, and for this to work out we also need your permission to share your scenes/minidumps with them.
Hey! I still have this problem, any updates about this? Thanks!
Hi guys,
Indeed, the crash issue is very very strange, we are trying to find some solutions, but at the moment, best option is to use lower res maps (2K, 1K), or the Box Method. The OSL seems to be pretty clean, already asked two OSL devs to double check.
What I am trying now is to convert EXRs to TX files, someone has suggested that it is a very efficient way to render textures because it automatically downscales and upscales the textures depending how far or close you are to the plane. TX format also loads much faster and allows for thousands of planes to be rendered without running out of RAM. So far, some tests were quite successful with this format, aside from some error messages by corona/vray renderers, but it didn’t affect the rendering.
If you have access to Retail Pack 2, we added an Experimental File into Retail Pack 2 folder on gumroad, please give it a try.
If anyone else without Retail 2 access, is interested to try the mipmapping tx file type, please let me know.
Best,
Art
Bumping this one up.
Anyone has used OSL wPrallax successfully in production with Max 2024 & Corona 11 Combo?
Are crashes still present or has this been somehow fixed?
Hello everyone! I still have this problem on 3dsmax 2023/Corona 12.1, is there a solution?
In my opinion no, I stopped using almost all OSL, not just this one. The risk of random crash was just too high.
The alternative for Parallax planes OSL, is just .EXR mapped box. It works just as good, but requires positioning a box instead of just plane… it’s less useful, but still useful.
Hi everyone,
I know how frustrating it can be with those random crashes…still looking for solutions. I have just added TX Version in the Free Scene, for people to test out. This TX textures were already included in Retail 2 and Lobby 1 packs, but I haven’t heard anyone use them yet, and what were their results.
I would really appreciate it if you guys could give it a try, please not, delete all the EXR planes in your scenes, otherwise it will not count as a test because OSL might crash again using any EXR texture. So please only test with those TX OSL planes in your scene, create alot of planes (like at least 40-50), please also create not just instances, but also many copies, to have some variations.
If you have Lobby pack 1 or Retail 2, please also try only using TX OSL planes and let me know how it goes, when I was testing the TX textures it worked well, especially the 2K ones, the mipmapping is automatically reducing the size of the texture from 2K to tiny size when viewed from far away. If those TX textures are successful and people have no crashes, then I plan to convert all wParallax to this format.
Free Scene: wParallax Free Scene
Art Maknev
