Hello!
We recently discovered that corona interactive render crashes when we use the new multithreaded plugin tyflow! Only when interactive render is enabled!
Just a heads up ![]()
Thanks!
Hello!
Thanks!
Thanks for your report. We will look into this ASAP.
Which version did you download in the dropdown list. Does both VRay versions work?
Thanks.
One of the options says ‘…or no Vray’, I guess that’s the one we should install.
I’ll give it a try. Must of meant not VRay.
Oh never mind their latest release for vray next works with corona interactive!
