Crashes in both Revit and Sketchup with Oculus
I have a lot of problems with oculus rift / sketchup / revit / steamVR / enscape
I’n not sure where the problem is - if it is a encsape problem, but it seems so…
Whenever i start VR in sketchup or Revit - SteamVR seems to crash.
I can start Oculus Rift, and from here Google Earth VR, witch uses SteamVR also - and it works just fine.
I havet tested both the latest preview version, and the version before that.
Does others have theese issues?
Jorgensen
You don’t need to run SteamVR for using Oculus Rift with Enscape.
=>We only use it for HTC Vive and windows mixed reality headsets.
I haven’t heard about that behavior connected to Enscape in particular so far.
I had the same behavior in general when SteamVR tries to conntect to a headset which is already busy. So I don’t have SteamVR in Autostart any longer and only start it when I need it.
Which versions of Enscape, Oculus and SteamVR are you using?
hi jonathan
thank you for getting back to me.
when i activate the vr headset in enscape - steamVR starts right away. And after a short time steamVR says (unresponsive) SketchUp.exe
i can see that it works fine in the enscape window - the model is shown and its responses to the movement of the HMD, but in the HMD i just see a white rectangle on the floor, the green border net, and then a large black floor.
i don’t know that’s going on :frowning: maybe i could help if i could prevent steamvr to startup - but i did not find this setting.
I use
Windows 7
Enscape 2.1.2
SteamVR is set to use the lasted beta version
Oculus - i’m not sure as i can’t find that information
Oculus Rift - lasted model
Sketchup 2017
Jorgensen
Please make sure that the latest Oculus software (download) is up and running (without detected device errors) before you enable VR in Enscape.
@Jorgensen_dk
There is a specific option for it in the developers tab of the Steam VR setting:
Start SteamVR → Settings → Developer → Disable option “Start SteamVR when an application starts”
! Be aware that you have to start SteamVR manually after that action.
i have downloaded an installed the lastest version of oculus software.
when i start sketchup, there is still no connection between sketchup and oculus.
i can see the movements of the HMD in the enscape window - but there is just a small white rectangle and a large black floor when i look inside the HMD.
the same for revit - but here i get a white floor, and a 2d screen flowting in front of me saying “revit.exe loading.”.
i tried the aircar demo in the oculus library - and it works fine.
has anyone had this kind of problems?
edit - i did deactive steamvr.exe, so it does not popup when i start enscape.
thanks
jorgensen
Have you checked our knowledgebase article about using VR HMDs?
You have to allow input from “Unknown sources” in the settings of your Oculus Software.
