Crashes using vrayRT
Quite often when using vrayRT it will crash if I delete a max modifier or add a modifier or do anything other than just adjust materials. Becoming very frustrating!
Can you share the scene and some steps to reproduce the crashes ?
Also - when you get a crash - Max and/or V-Ray will create crash dumps. They are located in your temp folder and are called 3dsmax_minidump.dmp and vray.dmp. Can you go to the temp folder, delete any old dmp files and after that reproduce the crash? When it happens - send us the new dump files.
Yavor
