Not sure why this is happening. Only when using DR will my machine CTD with a max error.
It seems to crash when I’ve sent all the vray mesh assets to the DR nodes. I’ll check all nodes have been updated to the latest version. Could it cause a crash if one hasn’t been ?
It’s may be possible.
This is since updating to 3.2.10. I found one node that didn’t have the update applied so trying again now.
Update: Still crashing !
It seems to be related to the vrMesh files. I converted a whole bunch of objects in a group to vrMeshes. If I hide them it still sends them to the DR nodes even though it will not appear in the render. If I delete the group the render goes fine. I do need the interior of the car included. Could it be related to dynamic memory ?
No, I don’t think so. Do you get a CER dialog? If yes, can you send me the 3dsmax_minidump.dmp from the user temporary folder to vlado@chaosgroup.com?
Sending the mini dump file via email now. Thanks
I seem to have resolved the crash by deleting a number of meshes that were not needed and re-exporting out as vray meshes. I lowered the visible faces for proxy viewing. Seems fine now. Not sure what will show up on the mini dump.
