I’ve had a look at the scene but still couldn’t reproduce the above mentioned crash. Are there any specific steps which need to be executed, any specific object to be moved or it happens non-deterministically? Also, would it be possible to provide a vraylog and a .dmp file (both located in %temp% directory) ?
Thanks for taking a look. I can reproduce on my end by starting IPR mode, double clicking “CTRL_BARREL_COG” to select it and all the linked objects, entering isolation mode, and then exiting isolation mode.
As a workaround for isolating objects, I would recommend using debug shading IPR (isolate selected mode) functionality, which would provide more flexibility.
