Is anyone else having problems with 1.5 crashing out of Max (I’m actually on Viz 2005 though)? Since I’ve installed it with the virtual dongle and tried it out I’ve had very frequent crashes, like every 10 min. or so, sometimes as quick as 30 secs. I’m still trying to see if there’s a pattern to it but I can’t seem to recognize anything, sometimes it’s when I’m in the material editor, sometimes when I’m moving the camera around or adjusting settings, but never during rendering (but sometimes when I cancel).
I set up 1.5 in a copied directory of Viz so I still have 1.47 running and I can work all day in that with no problems. I’m thinking that it might be related to instlling it in the duplicated directory. I could install 1.5 in the normal plugin directory but with all of these crashes I’m very hesitant.
Yes, I have had similar problems. VRay was loosing it’s connection to the license server and would take forever to time out on the ME or often would crash. I thought it was just my bad home network…anyways I haven’t had an issue since I disabled the vrlserver as a service and just run it as a program from my startup folder.
Since you are using it with the virtual dongle, which program is in your startup folder? The “virtual dongle” does not require vrlservice.exe or vrlserver.exe to be running at all if you have a local license on your machine.
Do you click any other buttons between showing the VFB and clicking the “Show correction controls”? Is this during the rendering or after rendering is complete?
Well I tried to find a pattern to determine when exactly the crash occurs; so far I can say that it does not seem to be affected by the display driver (tried open gl, direct 3d and software → crashes everytime) the crash occurs every time when I press the button during rendering time, even when no GI is calculated… I think I remember that at one time it even crashed when I pressed the button after the rendering was finished, I will try to repeat that. All test scenes I used were very simple (boxes, 1 vray sun, 1 vray physical camera, vray-sky).
I was referring to dlparisi’s problem when I mentioned the display drivers; I’m sure they don’t matter for the VFB In what way does 3dsmax crash? Does it create a crash dump with the option to send to Autodesk? If this is the case, you can try to email me the file 3dsmax_minidump.dmp which is created by the 3dsmax crash handler in the temporary windows folder right after a crash (this is typically “c:\documents and settings\\Local Settings\Temp” unless changed manually).
… well I just rendered my test scene again and this time it even crashes without touching the “show correction controls” button (last time just after the rendering was finished…) I will check if it has something to do with vraysun/vraysky…
The graphic card is a Geforce 6800 (I think a version with only 128 MB RAM). Drivers are (referring to the windows hardware properties tab) version number 8.4.2.1, Date 09.03.2006.
I’m using viz07, and I found that if I use PPT (just for previewing/testing) I can only render once. If I cancel the render and then start again, it crashes viz. Doesn’t happen with QMC/LC.
Although without the use of the physical camera the crashes are not occurring every time, I still experience regular crashes which seem to accumulate when I switch from the 3D Studio window to another application window (e.g. Firefox). Another crash trigger is vray fur, which seems to be nearly as bad as the physical camera on my System → crashes approximately at 50% of all render attempts…
All this seems to me somehow viewport- related to me (particularly the switching from and to 3dsmax/VIZ). Did you have a previous build of V-Ray on that machine? If yes, did it work?
I sometimes work from other machines so I have vrlserver to auth the license. Should I try running it without vrlserver running? Although like I said I’ve had no problems with 1.47 for ages now.
For video: I’m running a quadro 1400 with the maxtreme 8 drivers and 84.26 video drivers.
I’ve emailed you the acminidump.dmp files (hope these are the right ones as they don’t start with “3dsmax”).
Also, I’ve been running it a bit more this morning and had no problems, tried using vraysun, sky, cameras, with no problems until I tried rendering to the VFB with these components. I Alt-Tab’d to another window (vray forums ) and Viz closed on me. This generated the minidump file I’m sending you. Maybe it’s just a coincidence with the VFB though.
