I experience this a lot. I believe it may have something to do with my RAM resources. My current hypothesis is if I have Photoshop open with files open and I try to render in Enscape. Enscape + SkechUp will crash. If I close out of PS and do the same render works perfectly. Not fully sure if RAM swapping is causing the crash but the current work-around seems to be helping my situation until I can get more memory.
Do you have Photoshop running in GPU mode? This would explain out-of-memory crashes because Photoshop, as well as Enscape, may use really a lot of GPU VRAM.
The easiest way to give you a definite answer to this problem and what it’s caused by is to receive a dedicated feedback report with log files generated from your machine. Can you please do that? I do suspect that it’s an out of memory issue, but again, we can tell you the exact cause after we had a look at your report.
Something has changed since last week if it worked well back then.
Driver update? If so - try to roll back to the previous version.
DeviceLost ist very often (but not for 100%) a sign for the insufficient memory. Another GPU memory consuming application running in background? Maybe you changed capture resolution to some huge one?
I hope this will help you to tackle the issue. Otherwise we will see what is wrong from the logs.
Thanks Alexander - my system has the latest and greatest of everything so I don’t believe I have a memory issue.
A shout out to Phil Read (he helped me when I was deciding to purchase Enscape)
I unchecked the RTX Raytracing and was able to render at max resolution (8000 ppi) without any trouble. I sent this information along with my log files to Enscape.
This is the latest problem with Enscape. When I try to load a large model, it churns for several minutes with nothing happening. I close the Enscape window and try to start it again, but this message comes up:
The model is 222 mb, so quite large. I’m running the latest preview version and a 2080ti. I’m about to update my graphics drivers and see if that makes a difference.
In addition to sending us the project, if possible, please also kindly send us a feedback report with a link to this thread in the submission form for reference:
Is a 1.1GB Sketchup model too big for Enscape on a 2080 Ti? When I launch Enscape is gets to about 60% and then I notice the CPU maxes out and then crashes both Enscape and Sketchup. I did send the latest crash/log files the last time this happened.
It depends on what takes up that space. With 1 GB of pure geometry data you will very probably have some issues. Not memory related though.
We have received it, thank you! According to the logs Enscape detects it is frozen and shuts down. It may be a false positive, because the project seems to be pretty big and some operations may really take longer than expected. We collect such cases to find a good solution. Thank you for providing your case again! It would be great to have the project too to have a repro case to work with, if possible. Contact me via PM if you can share it.
A temporary workaround for you would be to switch to the draft quality mode - freeze is detected while preparing data structures for global illumination rendering.
Thanks for getting back to me. We were able to get it loaded into Enscape by turning off the RTX Ray Tracing for now.
Unfortunately, I am not able to share the model as it is confidential.
Demian responded with this:
“I’m afraid, this looks like an issue we’ve recently discovered and fixed today. A fix will be contained in an upcoming version very soon, there is I’m afraid no workaround available at least with the current version of 2.8 just yet.”
As you are a developer, would you be able to try and explain what the issue is/was? So we may better understand?
@emcminn it was a multithreading issue. Geometry data could have been modified in one thread, while the other one was processing this data. This bug was for a long time there already, it’s just occasion that with 2.8 it started to be a problem, due to some other changes and tweaks. As it usually happens with undefined behavior bugs which are hard to identify and reproduce.
