today i tried to render a section through a building. i set the max camera tho orthogonal and set the far and near cut off planes to the correct distance. rendered fine with scanline.
then i switched the renderer to vray and then it just renders black..
tried it with disabel the max shade blabla but it still does not work.
any suggestions??
maybe the camera settings are not correct decribed here, cause i use the german version of max and don´t know all translations..
Ive been searching all week on a way to do cross sections of multiple objects and as Natty stated ScalpelMAX is your best bet. Its the only one where you can use 1 or many clipping planes and maintain caped holes on the oblects. To give you an idea Ive actually just orderd ScalpelMAX today for a current project I have to do cross sections of. Also there is squat for info on the web and the best I had found was a kind of tutorial/demo video at http://www.trinity3d.com
i did a kind of simple woraround: i just moved the camera 1500 meters away from the object. slice planes work fine now and its more or less orthogonal..
