Create a new Vray material
I would like to know how to create a new Vray material inside Revit.
Hi wagnerdesouza,
Use the V-Ray Standalone Material Editor. Here is a quick start video explaining how to use it: https://docs.chaosgroup.com/display/…tor+QuickStart
More info about V-Ray Standalone Material Editor can be found here: Chaos Docs
More tutorials: Chaos Docs
Best,
Ana
Just more three questions @Ana_Lyubenova :
I’m using the material override option (opaque and transparent), but some objetcs (trees) are with a pink color. Can I override the trees?
Can I use Vray Sun together with Vray Dome?
And, where is the parameters to change the quality of GI (Brute force, LC, IRR, Ambient Occlusion…)? *Not the presets in Engine tab.
Im 3ds max user so Im trying to find the same option in Revit.
Thank you :slight_smile:
Answering your questions as follows:
1. RPC objects cannot be overridden yet. There will be an option for this very soon.
2. You can’t use both of them together, either Sun or Dome.
3. As a user, you have access only to the Engine tab. There are many settings that are hidden in V-Ray for Revit in order to simplify it.
Let me know if you have any other questions.
Ana
