Hello there,
Just a small problem.
I?ve started testing RC2 and am a bit confused…
When chosing a objekt in rhino and having the plug in choosed in my objekt properties/material panell, I only get the alternative to choose a material but not to create one. :?:
why that?
create material
… will be fixed in the next release. Until you can create a material in the material editor befor and … .
create material
The reasoning behind it was that the user should do all of their material changes inside our material editor and not on a per-object level. But after talking with Micha I did hook the create/edit buttons to pop up our material editor. So for now you’ll just have to make your changes in the material editor and then select the object /layer you wish to apply the material to. Sorry for the inconveniance.
