We are using version 1.5 and I have setup my scene so that it works well with vray sun, vray sky and vray cameras.
However, now I want to produce a 360 degree panorama using the ‘box’ type camera from the Vray: Camera dropdown. This doesn’t seem to be possible if I use vray physical cameras - i.e. you cannot override the settings.
I suppose I will need to rotate the camera around 90 degree rotations and render 6 different shots. I have done this before using max standard cameras and it worked fine - I just wanted to know if I use an 18mm vray physical camera, will is give me *exactly* a 90 degree field of view?
