Creating an Air Diffusion Map
I’m a HVAC Mechanical Designer in Nashville. I want to be able to use Enscapes Light Mode in conjuction with Revit’s Lighting Model Families to create a sort of Air Diffusion Map.
I’ve been able to create a lighting family inside of Revit which the light source expanded out to where an air diffuser should throw air, but this doesn’t seem to transpose correctly into Enscape. This would definitely help out when designing large open spaces that require a lot of supply diffusers and return / exhaust grilles. If anyone could assist in being able to do that’d be greatly appreciated.
