I’m attempting to create a displacement map using the ZDepth pass. For some reason the entire ZDepth pass is not rendered - see attached result. What am I doing wrong? Thanks!
I am not sure that would work - since the zdepth is distance from the camera, the edges of image will be at a different distance than the center of the image, and since you’d have to set a really small difference between near and far for something like bricks, then you would likely get what we see here - it would work in the center of the image, but out at the edges, since the distance is significantly different to those points (given the small range of the distance map settings required), they’d show up as all black and all white depending on settings for near and far.
Hi Tom. Thanks for the quick reply. You may well be right. I have tried other camera types to no avail - even super telephoto. This is a technique I was able to use with Vray before making the switch to Corona. I wonder if it’s possible with C4D’s native renderer. If anyone has any ideas on how to create a displacement map of roof shingles, I would be greatly appreciative. I have Substance Designer, but not too proficient at it…
That worked great. Thanks for the help!
