Creating neighbours in Enscape / Sketchup
Hi There,
I am creating renderings for the front and backyards of a house and want to know an easy way to get neighbouring houses like the image attached without having to draw them up myself. Also would love to put the road and kerb side too, but I am finding the skybox downloadbles really poor.
Any tips and tricks are very welcomed as I am very much a noob!
Cheers,
Kate
Hey,
First off i’ve only used enscape with sketchup/revit. So if you are using another program hopefully someone else can assist.
So this might be something you already are aware of, but in case you were looking for the houses in the image above. They are located in the enscape asset library. They are in the street props category.
If you are looking for other “plug and play options” the Sketchup warehouse has many full houses, apartments, office buildings, and more. They are going to be larger geometry counts in many cases but you can put them on a separate layer/workset based on what program you are using.
I typically download a model from the warehouse and turn them into enscape assets in a separate instance of sketchup/revit. There’s plenty of information on the forum about this process.
