Creating only foam?
Is there a way to create just a layer of foam do put ontop of the beer? Like instead of simulating the whole thing, just modeling the volume of liquid in a cup then possibly using Phoenix FD to just add a layer of foam on top?
Thanks!
You can use Particle Flow to emit some particles at your desired position and then use those in a Phoenix Particle Shader in order to render them.
Thanks a lot!
