Creating Splash
I need to create a Splash of a big Fish jumping out and into the water. I tried to make it with Blender, the result was slow and looked like glue instead of good water. On top the intergration into 3ds Max was horrible. I tried it with Pflow, but Pflow is useless with the standart Boxes which comes with 3ds Max in my opinion. It was asolutely slow and the result looks like anything but water or splashes!
I asking myself if Phoenix FD can make it and if so, will the result looks absolutely realistic? Do I get some nice flying splash drops and wakes around the hitting points on the water surface?
Or do I need a totally different plugin or program to do it?
best regards
Rog!
By the way, I tried to install the demo of phoenix FD but I can´t find it in my installed 3ds Max!
realflow had a 30 day demo last time i looked.. that will give you what you need, but be warned.. -again last time i looked at it, 30 days was only just enough to learn it and get a good final result!
in the currently available version, phoenix has no splashes, however in less than a month a new version will be available supporting splashes+foam simulation and shader.
some preliminary results:
and a close up image:
WOW WOW WOW !
looks incredibubble.
That splash video is simply amazing!
Cool solution, but one month is too late I need it this week. I would buy Phoenix FD asap if I could make a solution you showed above. Do you think that could be possible?
best regards
Rog!
Stop filling simulator
By the way, I played a bit with the demo of Pheonix FD.
How is it possible to stop filling the Phoenix FD simulator (Domain) with water at a certain frame? And from this frame on I need to simulate a doplhin mesh jumping out of the water and back into the water. Maybe the recent Fluids are good enough for my splash simulation!
best regards & thanks for helping me!!!
Rog!
you can fill the container with a geometry source in brush mode, or using a script, like in the pool scene (btw, the splashes above are made with it), or simple with an animated source, like in the paints scene.
about your problem - we need some betatesting anyway, so we can consider to give you a build.
Wow that sounds promising :slight_smile: How can I register for betatesting, so that I can get the build as fast as possible to get the job done? The Dolphinproject is set up with Max 2011 and Vray 1.5.
If you need my email or customer details just let me know. And thanks for the help I will check this brush mode!
best regards
Roger!
ok, give me an e-mail in pm
Can´t find anything of how to use this brush mode!
Someone who knows?
best regrads
Rog!
My viewport hangs if I try to simulate the pool scene. And the setup for the Poolscene seems to be not right, there are few states not set for the Fuel part right?
best
r!
i tried it just before the attachment, no idea why this happens. the bad news is that tomorrow i’ll be not at work.
the pool scene does not use the fuel, the temperature is used as liquid. before the liquid extension, in phoenix 1.1 the low temperature was the only “solution” for liquids (it makes the gas heavy), and the pool scene was made in this manner. later it was transformed to use the real liquid abilities, but still uses the temperature channel.
The Viewport hangs because of OpenGL, now with Direct X it works, and the Pool scene is great!!
Ivaylo your videos with foam and splash are awesome, PhoenixFD take the best way ! Very nice result ! Now were are not oblige to do in Realflow to make nice water’s effects in 3DS max.
Do you have an idea if it will be possible to fill an object with Phoenix liquid and if I break it with Rayfire to have this type of interaction ? : http://vimeo.com/9520483
PS : Thank you for the tutorial to start with PhoenixFD. Don’t Stop to explicate tips and tricks, with vray aquatic, foam, splash shader too :slight_smile:
Bests regards Chaosgroup Team you’re great.
yes it looks possible to make this with phoenix. i know that the lack of tutorials is a big issue of our product and we will try to fix this, i hope the videos of Michael McCarthy are only the first step.
Thank you for your reply to create this efffect, I will try to do it. The videos tutorial are great, but the quality is a little bit low resolution to see menus and values. Good continuation !
