creating vraySettings node
I couldn’t find the answer to my question in the forum. Please excuse me if it’s there but I missed it.
I’m having a problem with a script that opens a new scene, does some things and renders in VRay. The problem is that the vraySettings node doesn’t exist in a scene until vray is selected as renderer ¿manually?.
I’m using the command setCurrentRenderer vray but this doesn’t create a vraySettings node just jet so when I try to set the render params y get a “setAttr: No object matches name: vraySettings.fileNamePrefix” error…
Any help would be greatly appreciated
Cheers,
Alberto - El Ranchito Imagen Digital
You can use the vrayCreateVRaySettingsNode() MEL procedure; it will check if a V-Ray settings node exists and if not, will create one.
Great! Thank you!!
Is there a place where I should be looking for this kind of info?
Bests!
