I am working on a scene with Ornatrix fur in it and using DR. My deadline is almost dead and I can’t go forward with those bluescreens. Can you help me please?
I sent the scene by email to chaosgroup support.
The message I get from windows 10 in the bluescreen is whea incorrectable error. But I hope the error is correctable cause I may loose a lot of money if I can’t render my job!!!
Displacement and GI are turned off and still getting blue screens.
I noticed at least one of my dr slave also restarted before my workstation while trying to render this.
It is not always crashing. I just render one frame cause I am tweaking my fur right now. And sometimes it renders entirely other time it will do that blue screen and restart the computer.
Max 2018.3
vray_adv_36003_max2018_x64_27812
windows 10 1703
i9-7980XE cpu 2.60 Ghz 64GB of ram
zotac 1080Ti mini
and my vraylog:
[2017/Nov/9|17:16:06] ============================================================
[2017/Nov/9|17:16:06] Console created, V-Ray Adv 3.60.03 for x64 from Nov 3 2017, 05:50:53
[2017/Nov/9|17:16:06] Compiled with Intel C++ compiler, version 16
[2017/Nov/9|17:16:06] Host is 3ds Max, version 20
[2017/Nov/9|17:16:06] V-Ray DLL version is 3.60.03
[2017/Nov/9|17:16:14] Constructor entered.
[2017/Nov/9|17:16:14] Setting default filter kernel.
[2017/Nov/9|17:16:14] “default” preset not loaded: Preset name “default” not found
[2017/Nov/9|17:16:14] Constructor done.
[2017/Nov/9|17:16:17] Resetting VRender.
[2017/Nov/9|17:16:17] Setting default filter kernel.
[2017/Nov/9|17:16:17] “default” preset not loaded: Preset name “default” not found
[2017/Nov/9|17:16:21] Constructor entered (loading from file).
[2017/Nov/9|17:16:21] Setting default filter kernel.
[2017/Nov/9|17:16:21] “default” preset not loaded: Preset name “default” not found
[2017/Nov/9|17:16:21] Constructor done.
[2017/Nov/9|17:16:21] Loading from file.
[2017/Nov/9|17:16:21] Loading filter parameters.
[2017/Nov/9|17:16:21] Adding host “anpanman”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “hakaba”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “hedoro”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “kaiki”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “kamakiri”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “kurayami”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “macurosuke”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “newegga”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “sasori”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “u1komori”:20204 from scene
[2017/Nov/9|17:16:21] Adding host “ufo”:20204 from scene
[2017/Nov/9|17:16:21] Loading done.
[2017/Nov/9|17:16:21] Constructor entered.
[2017/Nov/9|17:16:21] VRenderer destructor entered.
[2017/Nov/9|17:16:21] VRenderer destructor done.
[2017/Nov/9|17:16:24] Loading HDRI map “topCouetteDistri”
[2017/Nov/9|17:16:24] Loading HDRI map “Map #20”
[2017/Nov/9|17:16:24] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:16:24] Loading HDRI map “elengthMapBedain”
[2017/Nov/9|17:16:26] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:16:26] Loading HDRI map “elengthMapBedain”
[2017/Nov/9|17:16:27] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:16:27] Loading HDRI map “elengthMapBedain”
[2017/Nov/9|17:16:28] Loading HDRI map “topCouetteDistri”
[2017/Nov/9|17:16:28] Loading HDRI map “Map #20”
[2017/Nov/9|17:16:28] Loading HDRI map “Map 22”
[2017/Nov/9|17:16:29] Loading HDRI map “Map 22”
[2017/Nov/9|17:17:23] Loading HDRI map “topCouetteDistri”
[2017/Nov/9|17:17:23] Loading HDRI map “Map #20”
[2017/Nov/9|17:17:23] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:17:23] Loading HDRI map “elengthMapBedain”
[2017/Nov/9|17:17:24] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:17:25] Loading HDRI map “elengthMapBedain”
[2017/Nov/9|17:17:25] Loading HDRI map “distribution_Bedaine”
[2017/Nov/9|17:17:25] Saving to file.
[2017/Nov/9|17:17:25] Saving distributed renderer.
[2017/Nov/9|17:17:25] Saving filter parameters.
[2017/Nov/9|17:17:25] Saving done.
[2017/Nov/9|17:21:22] Loading HDRI map “Map 22”
[2017/Nov/9|17:30:18] Cloning VRender.
[2017/Nov/9|17:30:18] Constructor entered.
[2017/Nov/9|17:30:18] Setting default filter kernel.
[2017/Nov/9|17:30:18] “default” preset not loaded: Preset name “default” not found
[2017/Nov/9|17:30:18] Constructor done.
[2017/Nov/9|17:30:18] VRenderer destructor entered.
[2017/Nov/9|17:30:18] VRenderer destructor done.
[2017/Nov/9|17:30:37] VRenderer destructor entered.
[2017/Nov/9|17:30:37] VRenderer destructor done.
Jocelyn ?Strob? Simard www.strobfx.com
