Hello all. I’m working in Houdini 18.5 / Vray5, on a crowd system (fine) with hair (not fine). Some frames on some farm machines will complete rendering, but others will hang indefinitely at 99.88 / 99.76% completion. I’m using bucket style rendering (progressive seems to take 5x as long), and VrayHairNextMtl for the actual curve rendering. Groom is loaded as vrscene, then added to the agent layer already established. I’m ensuring to restrict transparency levels to 3, bucket size is lowered to reduce the possibility of failure, Embree is enabled, etc. etc. etc. VrayHairNextMtl indirect bounces are set to 1.
When it actually completes rendering it looks great, but I’m sweating buckets here as it’s not looking like I can actually use proper hair shading in a crowd system for final rendering!
hey Gram! Been a while! Yeah your vray version is quite old, I’m not sure what could be the culprit. Do the machines have enough ram? The hair is it being subdivided at render time? What happens if you crop the crowd to a small section - do they then render fine? Does the crowd render fine with vraymtl on the hair instead of hair material?
Hey Dmitri! Long time!! You read my mind though - farm machines have more than enough RAM (256gb), and I’ve already chunked out into three groups per shot, no subdivision at all. Testing tonight with standard VrayMtl hair shading, we’ll see how that goes. Wish I could figure out why VRayHairNextMtl is causing the render hangups tho…
Edit: With VrayMtl as shader (helmet hair) I’m seeing mostly successful renders, 2K @30m./fr. Any of my methods for rendering using VrayHairNextMtl were all failures.
next are you using gi? gi -on/off try it see if it makes any diff. I remember a long time ago there was some issue with LC getting stuck on some of these. I would also not use any transparency in the hair - at this distance it makes no sense.
Lastly, if the hair is curves you could bake it out to geo and try that, perhaps it will work.
For the agents themselves, I do need GI for sure. Indirect light is pretty crucial to the look. I could disable transparency completely, hadn’t thought of that… My limit was 3, but yeah I don’t need any I reckon.
i would play around with the gi options, if it was hanging on LC, then bf/bf would probably get through it.
Brute Force is a great idea! Thanks, gonna try that as well.
Any reason why you’re sticking to such older Houdini and V-Ray versions?
You should give VFH7.4 a try, we have recently asked the Chaos team to help improve the memory usage on two critical areas, crowd and instancing.
We now have scenes with thousands of agents, 5k to 50K (multiple LODs used, with hair and “helmet hair”) all under 128Gb of ram, and rendering quite quickly, 10-20 minutes at 1800x1800x2.0, this is around our half-res with “low” sampling, full-res with good sampling is ~1h.
These render times have full GI, no transparency clamping, motion blur, multiple lights, gobos, and the crowd is even rendered with another large chunk of the scene, and no crowd partitioning.
Best,
David.
I’d love to! We’re still getting over the dreaded python overhaul, so we’re using tech <py3 for now. We’re going to leapfrog directly into H21 / Vray7, it’ll be quite the change!
I am curious how you handle LODs…
