Cryptomatte denoiser seems broken
I selectively wanted to denoise part of an object in an animation. I can see that it works as it’s rendering but it is completely ignored when saving, thus denoising the entire image.
Wasted my 24 hours of rendering. Is there a fix, will it remain as it is and unuseable for animation, or is there some other thing I need to do to get it to work?
Switching to composite makes it save correctly.
Could you describe the problem step-by-step? Are you using a render mask or a render region?
The model is some headphones with glossy refractive side pieces. I needed these to be smoothed with the denoiser and for the remainder of the black palstic parts, which have the usual tiny noise and leather bumps, to be unaffected, due to the denoiser destroying that detail.
To do this I added a cryptomatte to the denoiser layer. With the source set to rgb it works correctly in the vfb. I assumed that that would be saved and didn’t realise until the render was done that it is in fact not saved.
I fthink it was some random googling that made me think to switch source to composite, which was the simplest of fixes and it works fine. Maybe that is how it’s supposed to work but I didn’t find anything directly stating this.
Do you save through the VFB or through the Render settings? Also, to what format?
Otherwise, it looks like an issue (VMAX-14219) that I logged some time ago.
It’s an animation, so saving through the regular Max save dialogue, as I only need png with the exact vfb look.
Okay, thanks. Will bump the issue’s priority.
