Cryptomatte ID type names are lost when Distributed Rendering is enabled
Reproduction steps:
- Create a simple scene with two boxes (example: Box001 and Box002)
- Add a VRayCryptomatte render element with ID type Node name (or any other type)
- Render to EXR
- Open the EXR in Photoshop (I’m using the EXR-IO plugin)
With Distributed Rendering disabled:
The Cryptomatte layers correctly contain the object names in Photoshop:
- VRayCryptomatte**.Box001**
- VRayCryptomatte**.Box002**
With Distributed Rendering enabled:
The Cryptomatte layers are missing the object names in Photoshop:
- VRayCryptomatte
- VRayCryptomatte
The specific ID type names are removed entirely and you are only left with the prefix Render Element name. This affects all Cryptomatte ID types: Node Name, Node material name, Layer name, Node user property
I’m using V-Ray 7.30.04 in 3ds Max 2024.
Thanks for the report. This seems to stem from another issue with DR in general (the last build that this would have worked was V-Ray 5).
I’ve logged it for developer investigation (VMAX-15638).
