Would it be possible to have CryptoMatte masks auto generate within Photoshop, when using the EXR-IO plugin?
When using Vray CPU, rendering to a single EXR, the plugin will create black and white masks from the cryptomattes, but the output from Vantage doesn’t do this. Instead I have to rely on the wand tool to select the mask from the coloured cryptomatte layer, which is just crap in all honesty!
Cheers,
Dean
Hi Dean,
In Vantage Cryptomatte is not currently supported. I think what you are referring to is either Object Mask or Material Mask. They are not at all the same as cryptomatte. They are similar to Wirecolor render element in result, though not driven by the wire color set in Max. I would advise you to vote for the idea in the Chaos Vantage Idea Portal here if you haven’t already done so: https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-60
Alexander
