I’ve heard that this is to be fixed in upcoming release. I mean cryptomatte changing id’s randomly in animation rendering, making it useless as matte maker. Is this GPU problem only or CPU as well. Is Cryptomatte suitable for animations at all now? If so, please tell me under what settings.
I have not had cryptomatte work with gpu progressive at all, but I do use it in cpu and animations. For the most part it worked fine and the comp side did not report any problems.
That’s what I thought - cpu CM works good. Okay, can’t wait for half of may, for 2nd update ![]()
We had an issue with Cryptomatte on the GPU in animations, which should be fixed in Update 2 in May.
