CScatter: Trasformation textures and Spacing/Jitter UV
As in the title:
(*) it will be very handy to have a checkbox on the right side of CScatter Transformation textures.
(*) Also, when we are in 1D - On spline mode, we should have two Spacing and Jitter parameter, for U and V (as Multiscatter)
Thanks you =)
Hi, thanks for the tips. Please, could you better explain your 2nd point?
Hello Mike, look at here:
Properties of distribution by spline
Spline distribution options are available if spline is selected as the object for the distribution over it.
Distribution by spline
Thickness: is the thickness of objects distribution in reference to spline (it is set in system measure units)
Proxy Distance: is the length and width between the objects with regular distribution. Be careful and attentive! Regular pattern of spline distribution needs Scale Mult option of the Regular Pattern Settings section to be set as 1.
(Internal ID=349322907)
1D scatter will not place object on spline with thickness and distance parameters like Multiscatter. But this is good function, we add into todo list.
done (I think ;))
