Hi there,
First of all, I know that im not writing in the right forum channel but it was the only channel where i was permitted to make a new post. I didn’t get the “new post” button anywhere else. sorry about that. (feel free to move this topic to its right category )
Well, my big problem is that I get this error while rendering in RT mode.
Im running max 2018 latest version, Vray the latest version, and with a GTX 1080 TI graphics card.
I have also updated the driver of the GPU this evening.
Its all running on Windows 10
Its so frustrating not being able to use all the power that I have in that GPU.
Can you please please help me with this urgent problem?
Thanks for the advice
For som reason when I try to install the driver you specified, it tries to install but eventually write, that the graphic driver could not find compatible hardware, do you know what could be the reason for that?
The warnings in the simple scene are not to worry - they just mention things from Adv that are not supported in GPU.
It might be a V-Ray GPU bug. Can you send the scene so we can check it?
We found the bug and we have fixed it in the internal builds.
We will port the fix to the stable builds and update you here when such stable nightly is be available (will take a while).
