CUDA error 716
Hi!
Im using 4 x GPU rtx 2080 ti, 3dsmax 2020 and vray next update 1.2 and im getting CUDA error 716 very often on random frames (quite heavy project). Previously i was working on machine with 2 x gtx 1080ti on 3dsmax 2017 and sometimes the same error interupted my rendering. What is this?
Thanks for help!
It could be anything. It will be very helpful if you can isolate the problem and send it to support.
ok i found the problem - gpu driver is dameged
@WAJORRO which driver did you use?
Would be nice to see as I’m still testing new drivers.
