cuda - vray interactive is not interactive
Vray Asset Editor/Render is set to CUDA and Interactive is on: When I make changes to Rhino “Texture Mapping”, the V-Ray Frame Buffer is not updating the change. If I stop the interactive render and restart it, the changes appear.
Vray Asset Editor/Render is set to CPU and Interactive is on: When making the same changes, the VFB displays the changes.
Is this intended?
thanks,
Jeff
Hi @Ibear888 ,
Which version of V-Ray is this? Testing with the latest V-Ray 5 for Rhino, all seems ok - see screen-recording. Can you provide more details, am I missing something out? Does it happen in every project? Thanks!
I figured out making a video. I’ll try to make one.
Great, you can use many applications to achieve that, i.e. ShareX. Will be expecting an update, thanks!
