Culture Pots
Hi everyone, thought I would share some image from my latest project.
Any C and C welcome
Max 7 and Vray 1.46
your plastic is excellent.
Thanks, its nothing special, just a simple vray material :wink:
animated dude :?:
Nik, its not animated, each frame is about 4 hours! I might tweak the setting and get something rendered :smile:
hi jacks02 i like the idea but you can improve that scene more whit more reflective points on your glasses and try not to burn out them on the floor use exponential tone mapping
Thanks Zuliban, I have less than 8 hours to complete this, if i get some spare time i will make some changes
4 hours eh, i hope that’s not 4 hours with DR :stuck_out_tongue:
yeah, looks great!
VRay is pretty slow in calculating transparent objects. I had to make an animation some weeks ago. In that animation an object had to fade transparent (the object looked close to those stacked pots). The render time increased from something around 1 minute per frame up to 55 minutes per frame!!!
Might be a matter of raytracing technique.
Mirko
Nice plastic jacksc02… I will to see the settings of that mat… is really nice, good work.
You guessed it Nik, that was 4 hours with DR, I had 10 buckets rendering each image!!
awesome work
