Sorry if it has been resolved early, but i didn’t find in the forum.
What happens with the slaves when they give the message “got DR requests from XXX.XX.XX.XX but currently busy with 0.0.0.0” or something like that… ?
It happens often, and it’s pretty annoying !
thanks a lot
is it a stupid question ?
timdog
March 4, 2010, 9:49am
3
I had that issue too and after loosening up windows firewall everything was working fine.
ah, ok, thank’s a lot Timdog !
i have shut down the firewall, but it’s still the same after a lot of tests today… toooo bad
vlado
March 8, 2010, 2:03pm
6
Which V-Ray version is that? How did the previous DR rendering terminate (normally or it was cancelled by the user)?
It’s still build 10624. It happens often when i cancel a render while testing.
Should i use another build ? (win 7 64 on maya 2010 64)
thank’s
vlado
March 8, 2010, 6:05pm
8
If you go to the V-Ray console window on a render server that gives this message, and press Ctrl+Break, V-Ray will write a dump file with the current state of the program. It will print something like ‘Writing crash dump to “C:\Users\\AppData\Local\Temp\VRay.dmp”’. Is it possible to send me one or two of these .dmp files to vlado@chaosgroup.com ?
is there any way to have the server reset the slaves via the batch command ?
regards,
I’m now launching final renders via a batch script
render. exe -vray bla bla bla render 1 bla bla
render. exe -vray bla bla bla render 2 bla bla
render. exe -vray bla bla bla render 3 bla bla
Nearly each time it finishes a render the slaves halt on busy 0.0.0.0 and have to be relaunched !
annoying… i have to test more for the next deadline
