Curtain Wall: Doors
I guess I posted this in the wrong subforum before, sorry.
Anyway, when using the “walk mode” we can walk through doors when these are placed as a door family.
But often Revit modelers also use a curtain wall to quickly create windows and doors because of the quick workflow. This is no problem for the BIM philosophy as well because the curtain wall panels can also be tagged as a door or window category.
](https://forum.enscape3d.com/wcf/index.php?attachment/13528-knipsel-jpg/)
Unfortunately, Enscape does not allow us to walk through a curtain panel door. Can we please make this happen? It would make navigating our models much easier since we use this workflow a lot.
Thanks! :slight_smile:
Collision setup/ Detection in Enscape?
Walking through plants
Turn off the fly mode in the .exe
It’s been mentioned a few times - I think it would be much better if you could tag certain geometry as “ethereal” so that you could ‘clip’ through them while navigating your model.
Thanks @Chalk_1 , I’ll forward your inquiry accordingly of course. :slight_smile:
