Add your request to one of the existing curvature map request threads, this has been requested quite a lot in the past.
by Curvature Shader mean “edge wear and tear” then in Corona you can do it with CoronaAO map and input bitmap in one of the AO node to add more realism. YT got more tutorial on that simply search it.
Is this true? AFAIK, curvature should be pretty inexpensive shader to calculate.
There is no out of the box curvature map in Corona yet. Dubcat came up with some ideas how to get it: https://forum.corona-renderer.com/ dubcats secret little hideout #msg86428
