Custom aspect ratio rendering problem
I have long term issues with rendering portrait aspect ratios.
I often setup vantage camera to aspect ratio of 4:5.
For quick preview I have set my display resolution to 800x1000px
But whenever I open High Quality Render dialog it show me redner resolution from my camera (800x1000) and dont remember last render setting (I render images with size 1400x1750px).
I thing it is because there is no preset of that exact aspect ratio, so it reset every time and load values from camera settings.
I laso find that I simply cannot render all cameras at once with my custom resolution. You could try to open render dialog, setup resoulution e.g. 1400x1750px, select All in Camera enqueue mode and hit start.
It starts rendering with my preview resolution - 800x1000px.
It will be very helpful if I be able to setup my own presets which I can then use. Just like are 720p, 1080p…
Hi, thanks for posting. Please check this thread, it covers the same request. I will add your thread to the list and raise the priority of this issue.
Thank for your work
