Hi agawrys12
I have, I think a similar issue, not sure if it is related, but sounds like it might be, hopefully helps sheds some light?
I have a really strange problem, that I have been wrestling with for days. First details of my setup:
- Revit 2023
- Enscape 3.4.4+94564 (Latest)
- Nvidia GTX 1660 16GB Driver Version 531.18 (Latest)
I have been trying to create some custom assets, following the instructions in the helpful Enscape webinar
Using the example Daft Punk Helmet shown in the video from TurboSquid everything seems to work fine. However if I use pretty much any other FBX or OBJ file I download from Turbosquid or CGtrader or any number of other sites, the custom asset creator process crashes out when importing the geometry. Now this happens with incredibly simple files as well as with complex files. The Daft Punk Helmets are pretty complex compared to things I have tried with (simple chairs, bed side tables etc).
Looking at the logs I see these lines when it fails:
3-01 13:05:14.437 86f4 [ERROR] OpenGL/Vulkan context lost: Vulkan Error: vk::Queue::submit: ErrorDeviceLost at queue submit.
3-01 13:05:14.437 86f4 [INFO] Error kind: RESTART
3-01 13:05:14.439 86f4 [ERROR] Caught close-exception in Async main loop: Close on RendererError!
3-01 13:05:15.520 86f4 [INFO] Device is lost, not submitting any more commands.
3-01 13:05:15.526 86f4 [INFO] Device is lost, not submitting any more commands.
3-01 13:05:15.611 86f4 [INFO] Update statistics MaterialDataManager : Added 1 Removed 4
3-01 13:05:15.612 86f4 [INFO] Largest instance counts:
3-01 13:05:15.613 86f4 [INFO] [GPUMEM] ModelRenderManager (GEOMETRY) current usage: 39.79 MiB
3-01 13:05:15.613 86f4 [INFO] Auralization ApplySwitchBuffer() complete!
3-01 13:05:15.613 5e44 [INFO] Physic thread ended normally. (0x5e44)
3-01 13:05:15.662 86f4 [INFO] Device is lost, not submitting any more commands.
3-01 13:05:15.698 86f4 [INFO] GPUQueries (VulkanExecutorQuery:TransformFeedbackStreamEXT), maxPools: 5; maxQueriesPerPool: 0 (of 32); maxQueriesPerFrame: 0.
3-01 13:05:15.698 86f4 [INFO] GPUQueries (VulkanExecutorQuery:Occlusion), maxPools: 5; maxQueriesPerPool: 0 (of 32); maxQueriesPerFrame: 0.
3-01 13:05:15.699 86f4 [INFO] GPUQueries (VulkanExecutorTiming:Timestamp), maxPools: 5; maxQueriesPerPool: 7 (of 512); maxQueriesPerFrame: 7.
3-01 13:05:15.709 86f4 [WARN] Swapchain::destroyResource() Timeout waiting for fence.
I saw some other posts about updating Vulkan (which I have done to the latest version).
I have tried older versions of graphics drivers and Vulkan as well and older versions of Enscape too
I have tried to play around with the files in Blender before exporting them to see what is different with the daft punk helmet and other files, I can’t see anything obvious. If I knew what caused the crash, I could just edit the files in blender first I guess (although this would be a pain), but at least I would know I guess.
I have attached the daft punk pbx as well as an example chair which doesn’t work. Hopefully you can recreate the issue, I have also uploaded logs when it works with the daft punk and fails with the chair.
I have also turned off hardware ray tracing as I saw that was often suggested as a solution
One last thing, that is the weirdest of all, if I import the daft punk helmet and then import another object that doesn’t work by itself, it then works! It is like the daft punk primes it to accept the ones it crashes on before.
Hope you guys can provide some advice.
One last interesting bit of information, I tried the latest preview release of Enscape today and all objects crashed out (even the daft punk helmets).
Files
Kai_Chair.zip (1000 KB)
DAFT_PUNK_HELMETS.zip (2.59 MB)
Daft Punk - Working.log (21.3 KB)
Simple chair - not working.log (82 KB)
