Hi. I need help with loading a custom asset that I’ve downloaded from Turbosquid. The file loads when I click ‘Import Geometry’ (i think) but in the preview box it says ‘loading…’ and that doesn’t change. I’ve tried .obj file and .fbx. Help!
Thanks.
Thanks.
Welcome to our Forum, I’m sorry to hear about that.
First off, can you send me a screenshot of that? Second, since it cannot hurt, could you kindly also re-install Enscape accordingly? Make sure you’re using our latest release as well, please. Thanks a lot in advance!
@arno_delange , does this issue still persist for you?
If so, is there perhaps a chance you could send me the problematic file(s) (you can use wetransfer.com to upload them and send me the link through a DM)? Or does this persist with any object you try to import?
Should the latter be the case, please submit a Feedback Report as well and let me know once you’ve done so. Thanks!
it happens with any object.. i can’t load anything anymore.. keeps hanging on loading preview
Thanks a lot for submitting the report - We’ll have a look and get back to you again asap.
Was a fix ever discovered for this? I’m now having the same issues after updating Revit and Enscape.
i went back a version and then it worked…
Thanks for the reply - Would this be a version of Enscape or Revit?
enscape
