Would it be possible to add a feature that allows importing camera animations using the vmresh format?
Creating these animations directly in Envision can be quite time-consuming.
Lumion has a similar feature where you can import cameras via FBX, as long as the model origin matches the camera origin.
I really enjoy using Envision—especially because of Anima—and this feature would significantly improve our workflow.
Submitted on AHA Ideas (ENVISION-I-3).
Hi, Kiyaga. Thanks for the suggestion! Could you elaborate a bit more? We can enable importing of animated cameras if these are present in the .vrscene file or the .fbx file. However, .vrmesh files do not contain camera information.
Additionally, could you point out what makes it time consuming to create animations in Envision? What can we improve/add in order to make it easier for you to animate quickly and easier?
Simeon
Submitted on AHA Ideas.
I do agree. Importing camera in .vrscene is also okay, as I have tested that camera import in Vantage and it does work. So the feature can be implemented that way.
My comment is based on the fact that creating cameras along paths or using tracked cameras is better in the native 3D software packages, as they allow quad view editing and have more complicated tools for editing keyframes regarding easing.
This used to be a function in earlier versions of Envision. I thought it worked great. Currently, my main issue with cameras in Envision is setting up different keyframes for position and rotation. I’d like to rotate the camera at a specific point in the animation, but when I do it doesn’t ease into the turn. I’m not too familiar with variations yet, so maybe that is a way to smooth the motion. It was just easier to control it in 3ds Max, then bring that camera in. It seems Envision cameras are best for straight pans, zooming or if the camera starts it’s rotation from the beginning of the animation.
Submitted on AHA Ideas by Tim Sienold.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
