Custom Designed Chopper Motorcycle
Well, seeing how this bike was sort of a learning experience in 3D chopper building, I’m calling this finished as is, but I figured I could still share the rendering with you all.
Hopefully the next bike will be much better :slight_smile:
Comments and suggestions are always appreciated.
Regards,
Andrew
very nice! its just too ‘blue’.
is there something wrong with the seat?
i like the V-twin, can we see a wire?
Nice image!
Maybe you can “lean” the motocycle to adopt a more realistic position. Seeing it just in equilibrium is a bit contrasting.
Looks like a really nice model with good materials, but it is as stated before way to blue..
-Tom
new rendering WIP will have a kickstand, a tilt, and some sort of environment that won’t just reflect the blue sky of the HDRI map.
Thanks for the comments :slight_smile:
-Andrew
the smiling skull on the back..great! :smile:
I really like rear wheel!!! 8)
The fuel tank is little “smakced” from top to bottom, I think…
P.S. Don’t put any kickstands. Don’t need one with this WHEEL!!! :lol:
Here’s the new rendering :slight_smile: Hope you guys like it…
Regards,
Andrew
the second image is much better…esp for all that chrome, but i have one question…why in a shadow?
show that bad boy off…it would be cool if the bike was framed by tree shadows..but not covered in them…plus you loose details on that intricate model by hiding it like that.
asango: very good crit… I definitely see that now… I guess I was more wrapped up in the cool shadows I got from the trees than the fact it’s covering up the bike a lot.
I’ll see what I can do about that :slight_smile:
Also, what do you guys think about adding some depth of field to this?
DOF would look good…but you have to be carefull…too much and it tends to decrease the scale of the object…then you would have a hot wheel and not a ear destroying chopper!
I have to say that I like the first image better mainly because of the minimalist look. After all, the focus of the rendering should be your incredible chopper model, not the hedges, grass, sidewalk, shadows, etc. And I’d be careful with DOF as it tends to turn scenes into miniatures if not done just right.
