Custom Interactive Render Size
It dawned on me this morning that it would be cool if you could set the size of your interactive render to be larger than your screen. It would be handy for doing region renders at full scale in “real-time”.
Not sure if it makes sense. Blowup would probably work better here. Or maybe I don’t understand the request?
A situation where what I’m requesting would be useful is if you wanted to check something like DOF at full resolution. If you could set the size of the interactive render, you could in theory region render parts of the image at the final resolution instead of being constrained to testing at 1920x1080,etc.
Does that make sense?
there are now 2 modes to do closeup in interactive - vfb zoom-in and pan&scan
Perfect solution Ondra, really stoked to test this out soon!
