custom material shader doesnt work in override....
i wrote a custom material shader for maya, all has gone very well until I put it in a override field of a basic surface shader( ex. Reflection Material. ), and in the final image, i got the object shaded in a basic shading. I looked in the vray_MtlOverride.cpp and I noticed that override’s shade() calls my overriding material’s shade(). I tried printing something when my own material’s shade() is called. But nothing was printed… So I supposed that override material has not called my material’s shade() at all??? How that could happen?? Am I missing something?
Best regards
thekraken
here is a simple pseudo code of my material shader:
using namespace VR;
// Plugin parameters
struct MyMaterialParams: VRayParameterListDesc {
	MyMaterialParams(void) {
// The plugin itself
struct MyMaterialMyMaterial: VRayMaterial {
	MyMaterial(VRayPluginDesc *desc):VRayMaterial(desc) {
	// From VRayPlugin
	void renderBegin(VRayRenderer *vray) { brdf_pool.init(vray->getSequenceData().maxRenderThreads); }
	void renderEnd(VRayRenderer *vray) { brdf_pool.freeMem(); }
	void frameBegin(VR::VRayRenderer *vray);
	// From MaterialInterface
	void shade(VR::VRayContext &rc);
	// From BRDFInterface
	BSDFSampler *newBSDF(const VR::VRayContext &rc, BSDFFlags flags) {
		VR::smile:iffuseBRDF *bsdf=brdf_pool.newBRDF(rc);
		initBSDF(rc, *bsdf);
		return static_cast<BSDFSampler*>(bsdf);
	void deleteBSDF(const VR::VRayContext &rc, BSDFSampler *bsdf) {
		if (bsdf) brdf_pool.deleteBRDF(rc, (VR::smile:iffuseBRDF*) bsdf);
	void initBSDF(const VRayContext &rc, VR::smile:iffuseBRDF &brdf);
	PluginBase* getPlugin() { return static_cast<PluginBase*>(this); }
	virtual PluginInterface* newInterface(InterfaceID id)
		if( id == EXT_RTMTL )
			return static_cast<PluginInterface*>((RTMtlInterface*)this);
		return VRayMaterial::newInterface(id);
private:
	// Cached parameters
	BRDFPool<VR::smile:iffuseBRDF> brdf_pool;
// Define the plugin
#define MyMaterial_PluginID PluginID(LARGE_CONST(2012022011))
SIMPLE_PLUGIN_LIBRARY(MyMaterial_PluginID, EXT_MATERIAL, "MyMaterial", "MyMaterial for VRay", MyMaterial, MyMaterialParams);
void MyMaterial::frameBegin(VR::VRayRenderer *vray) {
	VRayMaterial::frameBegin(vray);
void MyMaterial::initBSDF(const VRayContext &rc, VR::smile:iffuseBRDF &bsdf) {
    std::cout<< "initBSDF is called"<<std::endl;
	Color diffuse=combineTex(rc, diffuse_tex, Color(0.0,0.0,0.0),1.0);
    bsdf.init(diffuse, Color(.0,.0,.0), rc);
void MyMaterial::shade(VR::VRayContext &rc) {
    std::cout<< "shade is called" <<std::endl;
	Color alpha=transparency.whiteComplement();
	if ((rc.rayparams.rayType & RT_SHADOW) || rc.rayresult.realBack) {
        rc.mtlresult.color.makeZero();
		rc.mtlresult.transp=transparency;
		rc.mtlresult.alpha=alpha;
		rc.mtlresult.alphaTransp=transparency;
		return;
		computing
	rc.mtlresult.color+=result;
Is the newBSDF() method called for your material? It is possible that your material is wrapped in a MtlSingleBRDF material eventually, and that MtlSingleBRDF is attached to the node. In that case, it will call only the BSDF/BRDF functions of your material, and not its shade() method.
1. Is the newBSDF() method called for your material?
Yes, override shader called newBSDF() for sure, and it called only newBSDF() :frowning: :frowning:
2. It is possible that your material is wrapped in a MtlSingleBRDF material eventually, and that MtlSingleBRDF is attached to the node.
nope, my material is not wrapped in a MtlBRDF(If I have understood CORRECTLY what you talked about)… it was just in a lambert’s override material field…
could you PLEASE detail a little… i’ve been looking for the solution for 4 hours… it’s driving me crazy… :frowning:
best regards
Ok then; can you show me a .vrscene file with the material exported in this way? In any case, the solution would probably be to do what you need in the traceForward() method of your BRDF - i.e. derive your own BRDF class from VUtils::smile:iffuseBRDF and reimplement its traceForward() method to do what you need (you’ll still need to call DiffuseBRDF::traceForward() to do the regular shading stuff before that).
that’s very kind of you.
here is the exported material
BRDFMirror VRayMtl1@mirror {
  transparency_tex=AColor(0, 0, 0, 1);
  cutoff=0.01;
  back_side=0;
  trace_reflections=1;
  trace_depth=5;
  reflect_exit_color=AColor(0, 0, 0, 1);
  reflect_dim_distance=100;
  reflect_dim_distance_on=0;
  reflect_dim_distance_falloff=0;
BRDFDiffuse VRayMtl1@diffuse {
  color=Color(0, 0, 0);
  color_tex=AColor(0, 0, 0, 1);
  roughness=0;
  use_irradiance_map=1;
BRDFLayered VRayMtl1@brdflayered {
  brdfs=List(
    VRayMtl1@mirror,
    VRayMtl1@diffuse
  transparency=Color(0, 0, 0);
  channels=List(
MtlSingleBRDF VRayMtl1@material {
  brdf=VRayMtl1@brdflayered;
  double_sided=1;
BRDFDiffuse lambert2@diffuse_brdf {
  color_tex=lambert2@diffuse_brdf_color_tex@tex_with_amount;
MtlOverride lambert2@diffuse_brdf_lambert2@override {
  base_mtl=lambert2@diffuse_brdf;
  reflect_mtl=VrayMyMaterial1;
VrayMyMaterialMayaPlugIn VrayMyMaterial1 {
  plgDiffuse_tex=AColor(0.1, 0.5, 0.2, 1);
  plgDiffuse_tex_mult=1;
  plgThresholdHigh=0.9;
  plgThresholdLow=0.3;
  plgHighColor=Color(1, 1, 1);
  plgMedColor=Color(0.8, 0.8, 0.8);
  plgLowColor=Color(0.2, 0.2, 0.2);
  plgTransparency=Color(0, 0, 0);
MtlSingleBRDF lambert2@material {
  brdf=lambert2@diffuse_brdf_lambert2@override;
I will derive my own BRDF from DiffuseBRDF… so there is no way that override would call my material shade() methode then?
Thank you
Best regards
kraken
Well, you could attach the MtlOverride material directly to the node, instead of passing it through a MtlSingleBRDF material. You can do this for example with the post-translate Python callback.
Thanks vlado,
I wrote a new class derived from BRDF to do the things finally and that works well. Thank you for all your replies. :slight_smile: I will try the post-translate python callback later.
best regards
thekraken
