Custom quality settings
I like to have a custom quality settings option. But don’t remove the standard settings because they’re easy to use. Just add a custom one.
Especially for VR speed is very important and lot of times I need something between medium and high. I need the option to fine tune which option may be turned off to get a good performance and which one I need to get a good effect.
For example medium is good enough but mirrors looks complete fake/wrong because they only show the skybox. In that case medium is good but with the mirrors of high.
I’m dreaming about detailed quality settings too. What do you mean by custom quality settings? Object based settings? Or more details at a global advanced option tab?
Hey @GWD , thanks a lot for your request. There are no plans to implement something like you proposed any time soon I’m afraid, since we want to keep the “Rendering Quality” slider as the only main option for ease of use.
I can still understand your wish to have more advanced controls over the rendering quality alongside, so I can file this as a dedicated feature request if you like. :slight_smile:
I that case change my request to remove the reflections for mirrors at all in the medium setting. Reflecting the surrounding in a mirror inside a building is much worse then reflecting nothing!
No good idea, since the medium setting allow to get light into closed spaced from the environment and this effect helps a lot for lighting closed spaces. So, not all users want to skip mirror reflections at medium settings.
One slider for different parameters is a bad idea and it doesn’t help to pack more parameters in this slider. :wink:
Then this should be fixed an other way, but a mirror reflecting something completely wrong makes it much worse than reflecting nothing.
Should be fixed, but will not be fixed, I’m sure. But you could fix your problem by disabling reflections at your mirror material. :wink:
