Custom Resolution - Only Works Once
Has anyone had the issue with custom resolution settings reverting back to standard dimensions?
I have a few views set up which I am trying to export as square images (3000x3000).
I make a custom setting with these dimensions, and can export a view, however as soon as I switch to another setting, then back to my square setting, the resolution of the square setting reverts back to UHD.
This is quite annoying as the only way I have found around it is to remake a settings preset every time I would like to export an image. :thumbdown:
Thanks in advance,
Sam
