Would it be possible to be able to save custom settings when saving images in VFB?
Examples:
-Default location is always “Render Output” in the project file
-Default gamma as always 2.2
Perhaps I am missing something, but I go through this everytime I save,
I can’t speak to the default gamma but I believe you should be able to change the default location to save your renders through your 3dsmax settings under “(customize) → (configure user and system paths…)” Unless I’m totally missing what you are asking. In all my years of using max since version 1.0 Ive never used the “3dsmax Project” option so I very well could be wrong in my suggestion but thought I would post anyway in case it works the same
