The autosaving of CXR’s seem to be system dependent.
Currently, if we do a render and auto save is turned on, it’ll save a CXR into the folder we tell it to.
If a colleague needs to render something different on the same system; if autosave is still ticked, the CXR will be saved in the same folder and will overwrite existing CXR’s.
I have the autosave option disabled but the “automatic saving on render end” enabled. Since the latter creates the filename via timestamp it will never be overwritten. So I can render several scenes, regions etc. on one system and have all the files ready. Only downside is that the file will be saved locally and not on a network.
It’s not entirely what you are looking for, but could still help you out! At least until there is a better solution.
Just press the “?” in the “Output autosave” group: you can define tokens. If the defined filename would read for example “C:\temp%f”, the max file name would be part of the autosave file.
Edit: I just realized that some tokens are missing in the autosave token help, for example exactly that %f. Reporting it (#188837)
